Cams offline
  • 1 Reply
  • 972 Views
Tuby
If my wify was down for a few hours today.
When it came back on my cameras are off line.will they automatically re connect to my wify ?
And my app or do I have to manually remove them.of the brackets and start over again...
Or can it be done by the app?
Thanks in advanced
Though it can be a pain, I suggest starting by going to the cameras and removing/reinserting the battery.  If that doesn't work, then take the camera down and charge it.
When they lose the wifi connection, they can use a lot of power quickly because they are monitoring the wifi to try and rejoin.
No, since when the camera is disconnected from the network, the app can't communicate with it.
