  • 6 Replies
  • 684 Views
jfencl
I have 6 Pro 5S 2K cameras and only one is on the current firmware (1.060.34.0_18_4286fd3).  How can I update the others?  It looks like this current firmware has been out since Feb 27th.
ShayneS
After checking into this, the firmware is in a slow-roll out release and some devices may be on a different schedule. The devices will update as the firmware continues to make it's way to production.
Best answers
  • ShayneS
6 REPLIES 6
Rebooting the cameras (if connected to WiFi) or your hub is a frequent solution. Reinserting the batteries would do the same thing. If no luck, try removing one camera from your account to see if reinstalling causes the update to happen.
jfencl
Unfortunately, none of that worked.  It even did the "searching for updated firmware" when I re-added one and it still didn't find it.
Where are you? You may be in a region where the firmware is still rolling out.
jfencl
Idaho.  And like I said, one of them did update at some point.
@JamesC , @ShayneS , @BrookeN any thoughts?
ShayneS
