Cameras just come, and go…
I own a full set of Arlo Pro 5s without a base station and i purchased it a year ago and purchased the solar pannels because i thought it would fix the issue. Ive been dealing with this problem for about a year but i ended up not paying any mind to it because i always thought eventually they would release a software update for such an obvious issue, im very busy so i rarely got enough time to spend hours setting them up.
I spend about an hour trying to configure them to my correct settings but then after a while they just completely disconfigure themselves and seem to forget every setting i applied on it, even enabling spotlights during the day. They dont even lose connection they just stop sending notifications and sometimes even spam me random motion snapshots instead. And my doorbell just completely disconnects and only reconnects when i reset my wifi router on and off. I suspected its because i dont have a base station and obviously it didnt come with my setup because why would they include it in the purchase (of course). I factory reset them 2-3 times its the same issue, i have a very fast wifi speed and never had any lag or long range connectivity issue.
Are you using a schedule or do you have any automations set up? What rules do you have in your "Arm Away" "Armo Home" and "Standby" modes?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
