Cameras go flat after losing connection
Home internet went down for 5 days and in that time camera batteries went flat. They were on 90% charge previously.
Was your home wifi also down?
Or was the wifi working, but with no internet connection?
I am not certain but I believe the wifi was working but there was no internet.
The reason I am asking is that the cameras do use a lot of power when they are trying to re-establish their wifi connection. I don't know how that compares to the case where the wifi is up, but the internet is down.
Thanks Stephen. I can't confirm either way unfortunately. Would be good if connection attempts were controlled a bit then. On the other hand what does happen if the wifi is up but internet is down.
The camera will try to connect to the Arlo Cloud - but I don't know how often. Impact on power might depend on whether the camera is connected through a smarthub, or not.
Not something I've tried to test, and my internet service is very reliable, so I haven't experienced this scenario.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
