Camera won’t record
  • 1 Reply
  • 827 Views
Willfloyd
Bought 3 camera and get only two to record.
Third one says I found a premium something but then it says not enough iCloud storage.  This is the camera I really want to record. So I guess they sell you 3  but only two will record. Anyone else had this problem?
Third one says I found a premium something.
You need a subscription to get any cloud recording.  It is likely that the two that are recording are still on the Trial, but that the problem camera is not.
So go into the subscription area in the app to check for that.
