Hi, Is there a way to make the Pro 5S take a picture automatically every 5 minutes? Sometimes activity is too far away to detect motion and it would be helpful to be able to go back and look at historical snapshots. Thank you.
No. You can set up an automation to take a picture at a set time, but there is no way to make that recurring.
Hopefully they will add a way to do that.
Thank you for your reply! I think this would be a great feature to add... we'll see.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
