Auto geofence
Hello I have pro 5 camera, I have tried many things but can't get the status to change automatically whether I am home or week. All your instructions are with an older app.
Can you help?
Lars
Look at the FAQ you've apparently been using and click on the embedded link that points to the other version of the FAQ. The current app support both the old and new user interface (UI) so the FAQs are available for each one. You want the one for the 4.0 UI.
These are the FAQs you want:
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
Be sure any phones being used for this remain logged in or the automation will fail since a phone that isn't logged in will be seen as away from home.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
