Hello,
I just installed a new kit of 3 Arlo Pro 5S 2K
Two of them where supposed to connect via Securelink, but it’s grayed out in the settings menu of every camera.
The install location is Switzerland.
Can you please help me?
Thank you,
regards.
Stefano
Pro 5s
Risoluzione dei problemi
SecureLink is a function of both the Pro 5 as well as the security hub. If you don't have the security system (it's only available in the US at the moment) you have to use WiFi or a SmartHub to connect the camera, similar to the other Arlo cameras.
https://kb.arlo.com/000062832/What-is-Arlo-SecureLink-and-how-does-it-work-with-my-Arlo-system
Thank you for your reply jguerdat.
Does it mean Securelink is optional and is not currently available in Europe?
@stkuser wrote:Does it mean Securelink is optional and is not currently available in Europe?
It is definitely optional, and it requires that you also have Arlo's home security system. I believe that is only available in the US.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
