Arlo Pro 5s 2k recording time changes and motion sensitivity changes not being saved
  • 2 Replies
  • 1740 Views
Byedvob
I go to default mode settings and try to change the “record for a fixed length” to a shorter time and it’s no longer remembering the change. It keeps recording for 59 seconds. Motion sensitivity is likewise not changed when I try to decrease from High to medium. Is there something hidden that needs to be found to save these settings?
iPhone 14 with firmware 1.040.27.10-105-24777521
Byedvob
James, I checked routines and found that if I customize the recording duration there, it saves and I can shorten the length. Also can lower the motion sensitivity from there.
Just does not allow changes from the main Device Settings?
thanks!
Barry
Byedvob,
The settings should apply automatically for the default mode.
Are you using any custom configurations within the modes under routines?
Byedvob
thanks!
Barry
