chicane
I've had ongoing headaches with my Pro 5S cameras not detecting events or taking snapshots instead.
Today I did a side by side test with a Pro 4 camera in the same location. Both devices are on 2.4GHz and connected to an outdoor Ubiquiti AP (great signal strength for both). I did try the device on 5GHz and found it to be similarly flaky so reverted to a hopefully more stable 2.4GHz connection. Unfortunately not.
Since I have done this side by side test, the Pro 4 is detecting every event (and recording a video).
The pro 5 recorded video once, completely missed one event and recorded a snapshot instead for the third event. With the video was choppy and audio partially missing at the start, while the Pro4 was smooth and had audio for the full clip.
Both devices are active under my subscription, set identical under the routine (to record video), and smart notifications set the same.
I've had this replaced with a new sealed unit by support for the second time with the same outcome.
Are these devices inherently faulty? anyone else experiencing similar?
Best answers
  • BrookeN
    The firmware has started rolling out. It should be completed within the next week. As soon as that is fully rolled out the behavior you are seeing will be resolved.
  • BrookeN
    I have this escalated to the engineering team. I will update the community as soon as possible.
1,053 REPLIES 1,053
BrookeN
It is at 25% as of the 17 of this month. It is still rolling out.
roundball
Virtuoso
Virtuoso
@BrookeN   ‎2025-03-21 11:05 AM
Wow, running way behind...thanks for the update.
AlixO
My 5s cameras haven’t been updated since I was put on the 1.050.33.10_106_3a163f7 firmware a few weeks ago. That firmware was working fine, but has started missing events over the last week. I tend to not get updates on my 5s cameras unless I ask, or they’re forced.
roundball
Virtuoso
Virtuoso
@AlixO
I've had '106' problems since it came out.
Am tired of hoping every time they try something different that the 5s Cams will be error free...they haven't been able to get them right for over a year so I no longer assume they will.
Based upon history, I suspect the latest 5s Cam Firmware Update # 1.060.34.0_18_4286fd3 that's being slowly rolled out will probably be arlo's final attempt to fix the 5s Cams...and again, based upon history...I have zero expectations that it will be error free, so we'll be stuck with what we've spent our money on.
I just officially put some Pro4 Cams back in operation to start reducing my dependability on 5s Cams for trustworthy home security.
I can't depend on current 5s Cams reliability for home security...need to make a long term arlo decision based upon how the rest of 2025 goes.
a102768
It definitely isn't error free!
My wife and I got a fright yesterday when we suddenly heard someone walking around the house. It was just my son and his girlfriend, who were staying with us for the weekend, returning from a trip out and had gone straight upstairs but the Pro 5 had totally missed them pulling into the drive in the car to turn around then walking up the drive and coming in through the garage.
When I checked my old Essential camera, that had captured everything and saved recordings but we don't alert on that one as it is pointing at the road so captures lots of movement.
roundball
Virtuoso
Virtuoso
@a102768  @BrookeN
Exactly...the arlo 5s Cams have proven they lack the minimum required quality for a dependable home security / protection system.
If they haven't been fixable in over a year, they're not fixable.
AND...arlo has the audacity to raise the support price on 5s Cams !!!!
AlixO
@roundball
I agree - I have zero confidence at this point that any update will fix the issues that have been going on for the last year.
I looked at replacing my Pro 5s cameras with Pro 4 cameras recently - the Pro 4 cameras now cost more than the Pro 5s where I am (Australia). Presumably because they actually work, whereas the Pro 5s cameras don’t.
Still no update to my Pro 5s firmware - I’d almost put money on it not being automatically rolled out to my cameras.
GeneralMeow
If this is true about a slow rollout and still havent been fixed in a year, this is smelling like a warranty of merchantability problem.  When will Arlo pull the plug and hand over refunds, replacements of somekind?  Is the new embedded board design totally broken, as i've had the worst time joining those things to my wifi network where the Pro4s connected just fine.
I am tired of rebooting my Pro5s every week to get them to work correctly and missing events.  My Pro4s, Pro2s, Doorbells, and original Pros all work fine.
roundball
Virtuoso
Virtuoso
@GeneralMeow
FWIW, just for the heck of it, in addition to recently reinstalling some Pro4 Cams…I’ve
now even pulled out my old Pro3 Cams, recharged the batteries, installed them and they also work fine.
Has anyone here received the latest 5s Firmware update and has it fixed all the 5s issues ?
roundball
Virtuoso
Virtuoso
“…..Has anyone here received the latest 5s Firmware update and has it fixed all the 5s issues?..…”
From the lack of replies, am I to assume that none of the readers of my post received the latest 5s Firmware update and/or it didn’t fix the 5s problems ??
GW1a
@roundball my camera now has the updated firmware, but no noticeable improvement in my opinion.
AlixO
Hi @roundball - I haven’t received the firmware update yet and my Pro 5s cameras are still missing events.
@BrookeN - is the new firmware still rolling out?
roundball
Virtuoso
Virtuoso
Amazing that arlo takes this long, particularly with such years + long problems.
I still need 5s Cams updated to Firmware # 1.060.34.0_18_4286fd3
chicane
While the updated firmware did fix one specific issue (snapshots being taken instead of video) the unreliable event detection/recording (missed events) continues to plague the Pro 5 / 5S devices.
Either the device has a physical design fault that can't be fixed in firmware or their engineering/development team lacks the skill to fix it in a new firmware revision.
Or alternatively, the Arlo cloud storage platform we all pay for with our subscription is at fault.  Are they seeing the events being sent? do they have sufficient capacity to record every event from every subscribers device?
I have ruled out my local internet / wifi being the blame here. However, Arlo Support will blame the customer until the cows come home to deflect blame away from themselves.
@BrookeN. We appreciate your time and effort with getting test firmwares out for the old snapshot issue but this has now been resolved.  I think let's stop wasting time hoping this will fix the missed events issue. Is there any way you can influence the powers that be within your reporting line to get some direct answers to the above? I am available for a phone chat if you would prefer, just reach out to me by direct message.
roundball
Virtuoso
Virtuoso
@chicane
“…unreliable event detection / recording (missed events)…”
Thats the most annoying common problem I have with my 5s Cams.
Cant trust them to protect my family if they don’t capture each / every event.
AlixO
I had two big guys knock on my door last week - one of my Pro 5s cameras is directly above the door. They walked up to the door, knocked, and hung around until I got there - all of it completely missed by the Pro 5s. I can forgive the camera missing a bird walking past my door (although it shouldn’t even miss that) but not two men.
roundball
Virtuoso
Virtuoso
For All, FWIW.
Since I still had several 5s Cams that had not yet been updated to the latest firmware, just for the heck of it I opened a case with support, providing the serial numbers, and asked them to please notify "Jeff" .
I haven't heard back from anyone yet, but this morning noticed several more had been updated to latest Firmware # 1.060.34.0_18_4286fd3.
No idea if they actually did as I asked or if it was just a rollout coincidence.
Probably just a coincidence because there's still one 5s Cam that was not updated...will watch & see.
BrookeN
I did let Jeff know the serial numbers, however they are still on a rollout. So it is just a coincidence that they were moved over when sending that message.
roundball
Virtuoso
Virtuoso
@BrookeN
Thanks for trying to help…just have one left to upgrade now.
roundball
Virtuoso
Virtuoso
@BrookeN and All
FWIW...with more of my Pro5s Cams having the latest Firmware Update:
( # 1.060.34.0_18_4286fd3 )
I was ready to spend the next couple weeks watching for any more irregularities...but only had to wait a few hours.
DRIVEWAY 5s CAM:
Detected & recorded my wife's car leaving, then returning...perfectly.
A couple hours later, a UPS truck pulled into the driveway, driver got out and walked down the driveway right past my wife's parked car.
Driveway 5s Cam never recorded any of that UPS truck & walking driver.
FRONT PORCH 5s CAM:
Detected the driver coming over on the sidewalk approaching the porch, coming up the porch steps, leaving a package, photographing the package, walking down the steps, and walking away.
I'll Install a different 5s Cam on the Driveway tomorrow as a final decision-making effort with this never-ending 5s Cam mess.
GW1a
@roundball similar to my observations, the new firmware update has made zero difference, so feed up with this now, when is Arlo going to admit the problems with this camera and offer refunds or alternative models in replacement.
GeneralMeow
@roundball
I had 1 Pro5 on 1.060.34.0_18_ba887f3 and the other on some old 1.050.xxxxx code.  In the past few days the other one finally got upgraded to 1.060.34.0_18_ba887f3 as well.  Not sure why that 1 Pro5 was stuck on that old code for so long even after multiple reboots, it was probably a month or more.
The programmer in me looks at that hex number and says that number is higher than the code revision floating around as "current" ba887f3 > 4286fd3.  Not sure  if the version I have is old or incredibly bleeding edge?
The video still seems a little choppy (may want to use some buffering?) but I havent needed to reboot weekly like I usually do, so far.  i'm sure I jinxed myself.
chicane
I've noticed choppy video / low frame rate on both pro 4 and 5 cameras recently.
Also very inconsistent detection - sometimes very laggy (almost missing a car driving past) yet sometimes detecting it as early as it could.
I doubt this is local device firmware related.
I'm suspicious of the arlo cloud hosting platform. I know it's not my wifi or ISP.
GeneralMeow
@chicane
agreed, my Pro4s are the same - choppy, but work.  Hence why i said if they add some kind of better buffering that can make the video capture smoother.
My video doorbells are pretty fluid oddly enough.
roundball
Virtuoso
Virtuoso
@chicane@BrookeN and All
Well, you & I are certainly on different world networks...maybe that comes into play...dunno.
FWIW, I reinstalled 4 of my Pro4 Cams on WIFI just like the 5s Cams.
The Pro4 Cams never had any detection / notification / recording problems in the past...and they've not had any such problems since I reinstalled them a couple months ago.
In my years with sets of arlo Cams...Pro2 / Pro3 / Pro4 / Pro5s...the only camera model I've had these ongoing detection / notification / recording failures with is the Pro5s.
Been over a year and I / we are tired of it.  arlo needs to give me / us a replacement set of the latest / NEW / best manufactured production 5s Cams.
No previously owned / returned / tested / claimed to be OK 5s Cams !
