chicane
I've had ongoing headaches with my Pro 5S cameras not detecting events or taking snapshots instead.
Today I did a side by side test with a Pro 4 camera in the same location. Both devices are on 2.4GHz and connected to an outdoor Ubiquiti AP (great signal strength for both). I did try the device on 5GHz and found it to be similarly flaky so reverted to a hopefully more stable 2.4GHz connection. Unfortunately not.
Since I have done this side by side test, the Pro 4 is detecting every event (and recording a video).
The pro 5 recorded video once, completely missed one event and recorded a snapshot instead for the third event. With the video was choppy and audio partially missing at the start, while the Pro4 was smooth and had audio for the full clip.
Both devices are active under my subscription, set identical under the routine (to record video), and smart notifications set the same.
I've had this replaced with a new sealed unit by support for the second time with the same outcome.
Are these devices inherently faulty? anyone else experiencing similar?
Best answers
  • BrookeN
    The firmware has started rolling out. It should be completed within the next week. As soon as that is fully rolled out the behavior you are seeing will be resolved.
  • BrookeN
    I have this escalated to the engineering team. I will update the community as soon as possible.
1,030 REPLIES 1,030
roundball
Virtuoso
Virtuoso
@WLynne
BTW, have you received the Field Trial Firmware downloads yet ?
WLynne
I'm not sure, but I know that I have version 4.16.0._5 released July 17, 2024.  How about you?
roundball
Virtuoso
Virtuoso
@WLynne
Don't recognize that #...is that what shows for 5s Firmware in the device section ?
All of my 5s Field Trial Firmware numbers are:  1.040.28.13_152_2450fc
chicane
hi @roundball I don’t think that’s field trial firmware?
chicane
@WLynne can you provide the full firmware version (not an abbreviation)?
WLynne
An update regarding my Arlo Pro 5S security camera monitoring my front lawn and street. Between July 1st and July 28th, the camera did not record any footage on July 7th, 8th, 9th, 12th, 17th, 19th, 26th, 27th, and 28th despite the fact that all events were selected. Additionally, it was only recorded once on July 11th. My desktop is running Version 4.16.0._5 released on July 17, 2024, and my cell phone's Arlo App is running version 14.17_28700, released on July 20, 2024. Both devices are missing the same recordings for the period of time.  I was unable to share a desktop screenshot of the camera's feed settings for July.
roundball
Virtuoso
Virtuoso
@WLynne
You need to go into the device settings...then:
1) click the circle with 3 dots in it at the upper right corner of the screen
2) click the gear on the right edge of one of the jiggling names of a 5s cam
3) Click the > at the right edge of the camera name
4) Halfway down the screen see the Firmware #
WLynne
1.040.28.17_194_ac8359b
HardwareVMC4060AerH5
roundball
Virtuoso
Virtuoso
@WLynne
OK, looks like @BrookeN got yours downloaded OK...
WLynne
Thank you for the confirmation.
roundball
Virtuoso
Virtuoso
PS:
I'm still having the recent intermittent failures with:
1) Notification of motion detections being very slow or not at all;
2) Then a very...very...very slow appearance of the motion into the Feed;
Hopefully they'll get their act together on this during the next couple days.
chicane
I’m saying this very Lagi notification and publishing to the feed for all of my Arlo cameras, I suspect there is congestion on their service/cloud side.
Any chance of some honest information, @BrookeN?
roundball
Virtuoso
Virtuoso
@BrookeN
Some more info about the tardy notifications of motion detection and tardy showing them in the Feed:
I just turned on some Pro4 cams and then walked through the house forgetting they were on…every one of the Pro4 cams notified immediately and posted to the Feed right away.
But the 5s cams have been intermittently very slow for 3 days now.
chicane
@roundball what country are you located in?
roundball
Virtuoso
Virtuoso
@chicane
US…..you ?
roundball
Virtuoso
Virtuoso
@BrookeN
PS:
The Pro4 cams are on a Base Station.
( 5s cams are on WIFI with the FTF )
chicane
@roundball Melbourne, Australia.
WLynne
I asked myself that same question.
WLynne
The same for me
WLynne
Thanks for the helpful info.
roundball
Virtuoso
Virtuoso
@WLynne
Another thought.....following some of those same steps I gave you yesterday:
Look at each of the individual settings underneath each camera in the device section...especially check to see that you have the proper "activity zones" defined for the view you want to check for motion of each camera.
chicane
@roundball that is not how activity zones work. Without a zone defined it will detect all motion. The zones are if you want to mask off areas by selecting zones to detect.
roundball
Virtuoso
Virtuoso
@chicane
Ahh, didn't know that...always assumed when I'd see that little small colored activity zone in the upper left hand corner of the screen that it was a default starting point, thanks
chicane
@roundball don’t worry, all good.
The stooges at Arlo Support would’ve made us all jump through hoops pretending that was the issue/solution with these pathetic Pro 5/5S cameras.
roundball
Virtuoso
Virtuoso
Just some info update:
My 5s cams are still slow to notify detected movement.
And are still very, very slow to then post anything to the feed.
( Pro4 cams still do all that perfectly )
Anyone else seeing any speed improvements in 5s detection notification & then posting to the Feed ?
Heard of any progress being made on these problems by Arlo ?
Heard any date when routine 5s public Firmware will be avaliable for use to download as we want to?
