Best answers
The firmware has started rolling out. It should be completed within the next week. As soon as that is fully rolled out the behavior you are seeing will be resolved.
I have this escalated to the engineering team. I will update the community as soon as possible.
The image you sent shows as a yellow triangle...can't see the ##.
Ref chatting....with arlo or Xfinity ?
After all the changes...now suspecting Internet...I assume someone has had you do a power off / power on of your network equipment to reset it ?
1.040.28.7_93_caa9491
I chatted with Arlo and Xfinity. Both say that everything is working on their end………….
These are the two Firmware #'s I have.
( I assume they would be the same on any of our 5s cams )
5s Standard Firmware # 1.040.28.7_93_caa9491
5s Field Trial Firmware # 1.040.28.13_152_2450fc8
EDIT UPDATE.....our replies passed each other.
And after all that, have you done a network equipment power off / power on to ensure reset activity picks up your changes ?
@roundball fwiw my Ubiquiti Unifi wireless show's the wifi connection to the Pro 5S as stable/excellent.
The fault is something more internal to the camera rather than its wifi uplink. I appreciate your anecdote however I doubt a base station being included will avoid these problems.
@BrookeN look forward to a factual update and response to my previous questions when you can. Thanks.
@roundball My cameras have had both firmware updates. The one I posted is the most current one. I’ve spent an hour with Xfinity; total of 5 agents and still couldn’t find an issue. Pointed fingers at Arlo. Worked with at least 6 Arlo agents and they pointed fingers at Xfinity. Any recommendations on other security cameras?!? 😆
Strange situation for sure...by contrast, I have:
Two 5s cams on a base station that have worked perfectly for a couple weeks now;
Two 5s cams on WIFI with the Field Trial Firmware that have worked perfectly since we got the Field Trial Firmware.
@roundball I don’t know what else to do except return the cameras and try a different brand.
I'm sure you're frustrated...may be at your 'red line'.
( Wish you were close by so we could try one of your cameras on my Network )
PS: a couple times over the years I've completely deleted the arlo app off my iphone and downloaded a full fresh copy from the app store in case something had gotten glitched in my app....you might do that just in case.
@roundball I will try that.
I can assure you that deleting/reinstalling the app will make zero difference.
I’ve spoken to the L3 team and they know what the fault is they can see errors in the device logs.
Gert and I are not talking about WIFI related issues...we're simply trying to get a standard 5s to work on his base station.
@roundball The wifi uplink is the point of difference though between a base station vs. direct wifi connected.
Hi @BrookeN - in a bizarre development, one of my Essential Spotlight cameras (side garage) has started sending me motion notifications without recording. It’s done it twice today. The Pro 5s used to consistently send motion notifications without recording before they were put on the field trial firmware (they haven’t done it since). The Essential Spotlights have never done it, until today.
@BrookeN my front deck pro 5s on field trial firmware just did a snapshot instead of video.. Ample battery level too.
I have had the same issue did you get it resolved
I just recently moved one of my cameras, and I expected it to get triggered more where it’s at, but it’s not. Then I realized, watching a video from one of my other cameras that this camera is getting triggered, because I can see the light come on in the other video, but it’s not sending recordings! Very annoyed…
This is for everyone on this post can you please let me know which ones of you are seeing the snapshot instead of recordings, which ones are seeing the grayed out low light motion, if neither of these let me know what behavior you are seeing. If we can leave the responses this time just to answer the questions above so I can get a better idea that would be greatly appreciated.
Hi @BrookeN for clarity, please provide an answer to the two questions previously posted (quoted below)?
1. If you are so certain that it’s only a subset of users who are only on this thread, what is the defining factor for the issue in the first place?
2. Does it affect direct wifi only (not arlo base station) connected cameras like someone has hypothesised?
I think you'll find that they probably have no idea themselves. However, I'd like to be surprised!
I have 2 Pro5s cameras connected to a Base Station.
( with their normal Firmware)
Have never had any of the "snapshot instead of recordings, or grayed out low light motion" issues.
I also have 2 Pro5s cameras connected to WIFI:
Initially had a couple "snapshot vs. recording" issues ( but no grayed out low light motion issues ) BEFORE the Field Trial Firmware was installed.
Have not had any "snapshot vs. recordings" ( or grayed out low light motion issues ) SINCE the Field Trial Firmware was installed.
NOTE:
At night time, all my Arlo cameras operate in brightly lit fields of view due to bright LED yard lights that are on all night.
Pro5S is missing a lot of motion events and now taking snap shots for every motion detected. Nothing but problems with this camera. Tried restarting . Doesn’t help.
If you're using them on WIFI, and you don't have the "Field Trial Firmware" installed, suggest you message Moderator @BrookeN and ask her if she'll coordinate the Field Trial Firmware install for you...she's been a breath of fresh air in trying to help us with these 5s issues.
PS:
Meanwhile, if you happen to have a Base Station, you might try that...my 5s cams work normally on a Base Station with their regular Firmware.
Will do, thank you!
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
