Arlo Pro 5 Ping latency
I have noticed my Arlo Pro 5 drop connection frequently and caused battery drained , I have tried doing a ping test and found that its latenency will continue to have serveral ms constantly increasing to nearly 1000 then it will reset.
I can reproduce it even I put the Arlo Pro 5 next to my router.
Version : 1.040.28.17_15_ac8359b
Use the app to go to Settings, Support and select your camera. Scroll down to Contacts to see what official support may offer, including an RMA.
@GG4ever wrote:
I have tried doing a ping test and found that its latency will continue to have serveral ms constantly increasing to nearly 1000 then it will reset.
The camera is usually in a low-power state - and when that is the case, it does not respond quickly to ping.
I see this on my first set of pings:
Pinging 10.0.0.112 with 32 bytes of data:
Reply from 10.0.0.112: bytes=32 time=724ms TTL=64
Reply from 10.0.0.112: bytes=32 time=709ms TTL=64
Reply from 10.0.0.112: bytes=32 time=689ms TTL=64
Reply from 10.0.0.112: bytes=32 time=681ms TTL=64
That first set of pings will wake the camera up, and the ping times will go down. This is what I see a few seconds after the first test:
Reply from 10.0.0.112: bytes=32 time=93ms TTL=64
Reply from 10.0.0.112: bytes=32 time=77ms TTL=64
Reply from 10.0.0.112: bytes=32 time=68ms TTL=64
Reply from 10.0.0.112: bytes=32 time=49ms TTL=64
If your ping times are similar, then that behavior is normal (although obviously the disconnects are not).
回覆自 192.168.1.253: 位元組=32 時間=718ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=741ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=750ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=768ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=787ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=807ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=818ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=837ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=851ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=860ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=880ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=897ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=904ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=916ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=932ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=952ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=959ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=980ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=988ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=1002ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=11ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=22ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=39ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=50ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=63ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=76ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=94ms TTL=64
回覆自 192.168.1.253: 位元組=32 時間=114ms TTL=64
My ping test differs from yours, the latency fluctuates between 10ms and 1000ms repeatedly
I just re-ran mine with a longer count, and got different results. There are short bursts (sometimes 20 packets or so) when the camera responds quickly, but then it lags again.
I am not seeing a gradual ramp up like your sample. Here's a sample from the end of the test I just did:
Reply from 10.0.0.112: bytes=32 time=1207ms TTL=64
Reply from 10.0.0.112: bytes=32 time=2ms TTL=64
Reply from 10.0.0.112: bytes=32 time=972ms TTL=64
Reply from 10.0.0.112: bytes=32 time=958ms TTL=64
Reply from 10.0.0.112: bytes=32 time=940ms TTL=64
Reply from 10.0.0.112: bytes=32 time=931ms TTL=64
Reply from 10.0.0.112: bytes=32 time=916ms TTL=64
Reply from 10.0.0.112: bytes=32 time=907ms TTL=64
Reply from 10.0.0.112: bytes=32 time=893ms TTL=64
Reply from 10.0.0.112: bytes=32 time=868ms TTL=64
Reply from 10.0.0.112: bytes=32 time=855ms TTL=64
Reply from 10.0.0.112: bytes=32 time=844ms TTL=64
Reply from 10.0.0.112: bytes=32 time=831ms TTL=64
Reply from 10.0.0.112: bytes=32 time=820ms TTL=64
Reply from 10.0.0.112: bytes=32 time=804ms TTL=64
Reply from 10.0.0.112: bytes=32 time=792ms TTL=64
Reply from 10.0.0.112: bytes=32 time=782ms TTL=64
Reply from 10.0.0.112: bytes=32 time=771ms TTL=64
Reply from 10.0.0.112: bytes=32 time=756ms TTL=64
Reply from 10.0.0.112: bytes=32 time=743ms TTL=64
Reply from 10.0.0.112: bytes=32 time=730ms TTL=64
Reply from 10.0.0.112: bytes=32 time=717ms TTL=64
Reply from 10.0.0.112: bytes=32 time=708ms TTL=64
Reply from 10.0.0.112: bytes=32 time=706ms TTL=64
Reply from 10.0.0.112: bytes=32 time=685ms TTL=64
Reply from 10.0.0.112: bytes=32 time=668ms TTL=64
Reply from 10.0.0.112: bytes=32 time=655ms TTL=64
Reply from 10.0.0.112: bytes=32 time=636ms TTL=64
Reply from 10.0.0.112: bytes=32 time=620ms TTL=64
Reply from 10.0.0.112: bytes=32 time=599ms TTL=64
Reply from 10.0.0.112: bytes=32 time=586ms TTL=64
Reply from 10.0.0.112: bytes=32 time=575ms TTL=64
Reply from 10.0.0.112: bytes=32 time=563ms TTL=64
Reply from 10.0.0.112: bytes=32 time=550ms TTL=64
Reply from 10.0.0.112: bytes=32 time=537ms TTL=64
Reply from 10.0.0.112: bytes=32 time=525ms TTL=64
Reply from 10.0.0.112: bytes=32 time=510ms TTL=64
Reply from 10.0.0.112: bytes=32 time=499ms TTL=64
Reply from 10.0.0.112: bytes=32 time=481ms TTL=64
Reply from 10.0.0.112: bytes=32 time=463ms TTL=64
Reply from 10.0.0.112: bytes=32 time=444ms TTL=64
Reply from 10.0.0.112: bytes=32 time=434ms TTL=64
Reply from 10.0.0.112: bytes=32 time=421ms TTL=64
Ping statistics for 10.0.0.112:
Packets: Sent = 200, Received = 200, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 1207ms, Average = 541ms
Do you always see a gradual ramp? Have you tried testing with a different PC?
I am still not convinced that the ping response is giving useful info on what is wrong. I don't have have your disconnect issue, and my ping times are also long. So I still think the ping response is sluggish due to the power management being done by the camera.
Have you measured the wifi speed at the camera location with your phone? I suggest using the Ookla speedtest app for that - turning off mobile data, in order to make sure you are testing the wifi speed.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
