Arlo Pro 5 – Live view & motion stop working on continuous power after latest firmware (1.060.35.0_2
Olivier_b
Hello,
Both of my Arlo Pro 5 cameras are showing the same recurring issue, which started immediately after the last firmware update:
  • Before the update, both cameras worked perfectly even on continuous power.
  • After the firmware update (current version: 1.060.35.0_26_fe51ebd), when connected to continuous power (with any Arlo official charging cable), after a few hours live view and video recording stop working.
  • The cameras remain connected (I can still access settings and restart them remotely), but video and motion detection are completely disabled until a manual restart.
  • When running only on battery, the cameras work perfectly with no issue.
Additional details:
• Model: Arlo Pro 5
• Firmware: 1.060.35.0_26_fe51ebd (issue only appears after this update)
• Camera #1: updated yesterday → issue started immediately after update
• Camera #2: was still on previous firmware and worked fine → updated last night and now shows the exact same issue
• Both cameras were purchased separately and come from different production batches/series
• Connection: tested both via Arlo SmartHub (model 4540) and direct Wi-Fi → same issue in both cases
• Wi-Fi network: stable and strong (Swisscom Internet Box)
• Troubleshooting already attempted: Wi-Fi 2.4 GHz only, IPv6 disabled, DHCP fixed IP, factory reset, reinstallation, SmartHub installation → none resolved the problem
Tested with different official Arlo chargers and cables:
 – Arlo Outdoor Cable 7.6 m
 – Arlo Indoor Cable 2.4 m
 – Original short charging cable included with the camera
→ The issue occurs with all of them
This clearly confirms that the problem is a firmware bug introduced in the latest version (1.060.35.0_26_fe51ebd) affecting continuous power mode.
Please advise on a solution or provide information on an upcoming firmware fix.
Thanks,
Best answers
  • ShayneS
    The development team is continuing to investigate the reports of this issue. We apologize for the time it has taken so far to isolate but we are getting closer to a solution. Due to it's complexity and our limited ability to reproduce the issue, we are taking great care to make sure we resolve the root cause once we have a fix available. We will continue providing updates as more information becomes available.
  • JudgeSweden
    I’m actually getting active help from Arlo L3 Support since a week back. We’re testing new FW (f216) and I’m sending them logs after I’ve done certain things, after their instructions. So please be patient. A solution is on the way.
  • JamesC
    We are continuing to investigate reports of this issue and the development team is working hard to find a solution. While this appears to be isolated to a very small number of users, we're continuing to treat this as a priority investigation. We will share more information as soon as it becomes available and our L3 teams will be in contact with the users here on the community who have reported this issue.
    Thank you,
106 REPLIES 106
JudgeSweden
It's actually newer and it seems to work, but more testing needs to be done.
Rcballa12
I'm also affected by this issue. We need a fix ASAP
Rcballa12
Yep. Same exact thing here
Olivier_b
@JudgeSweden @JamesC @ShayneS @BrookeN
Since today, the issue occurs even when the power cable isn’t plugged in… I have to restart the camera for it to become active
ClaudeFrog
Can it really be that difficult to fix this bug? It is a huge problem for many users but it seems that it is not your priority to fix it. Another thing I don't understand is that you keep invoicing users despite a system that is useless. I am soon losing my patience and then I will try to get my money back from the store where I purchased the cameras. And then I will start to warn the Internet from buying Arlo. American quality my a..
Rcballa12
The only thing that seems to help temporarily is unplugging from AC power
NovaCat91
Yep - which I just had to do. I had to remove the camera from power on Saturday as I left the location for the next 4 months. This is certainly not acceptable because I doubt the battery will last. I have changed  the configuration to be low power mode and pictures only. But I expect I will lose the ability to monitor before I can return and charge the camera battery again.
If this cannot be fixed Arlo has to replace the equipment.
