I have been using Arlo cameras along with Arlo Secure Plus Software/App since 2018. I like the hardware/software in general/overall but was hoping that with new hardware and AI based subscription software/app for secure plus, some of the irritants that trigger false alerts will go away…However are they still there and result in multiple false motion alerts daily for animal, so here are a few product improvement ideas for Arlo team to eliminate false motion alerts for:
1. Shadow of swinging tree/branches when windy.
2. Shrub branches swinging when windy
3. Fallen leaves rolling on ground when windy
4. Rotating fan blades of outdoor AC unit when it switches on
Anyone else have these issues, any comments from Arlo community?
i hope that the Arlo team will review and act on these suggestions.
VYP
Each of these are not the actual reason for false triggers. WHat is happening is the sun's strong IR being reflected and detected as motion. As the sun's angle changes, the issues will go away or at least change. The best way to fix this is to position the cameras to eliminate those items from view so the reflections are minimized. You can also reduce motion sensitivity while still maintaining the coverage needed but testing is needed.
Appreciate your feedback. I cannot change the camera location as that is the area I need coverage. Also have plenty of trees and shrubs so lots of shadows, motion when windy and don’t wanna cut them all. However, I will try reducing the sensitivity, hopefully it will help. Thanks again for your suggestion!
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
