what is the difference between dashboard arm away and arm home?
Details are here:
If you only have Pro 4 cameras, then the default behavior for both modes is the same. The difference is that by default, indoor models are only armed in Arm Away.
Note you can modify all three modes, so you can make them behave differently if you like.
Details are here:
Arlo Pro 4
labels
Samsung SmartThings
