pro 4 hub connectivity without wifi?
  • 2 Replies
  • 770 Views
Sherman4255
Will the pro 4 camera communicate with pro smart hub without wifi?
DannyBearAgain
Only if you have the vmb4xxx, 5000 base/hub.
https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
But you do need to have local wifi to use a mobile phone to do the initial setup unless you have a pc on the local network.
WHat is meant by "without WiFi"? You need an Internet connection to set up and use the system which can be done with either a wired connection (which is also needed for the hub) or WiFi (which is just a convenient way to not have to run wires to every device). If the OP has an Internet connection but no WiFi, it's possible to accomplish but still requires a router (which typically also supplies WiFi).
So, the question remains - what sort of network is being used to set up and use the system?
  • 2 Replies
  • 771 Views
