does arlo pro 4 cameras record in 4k with arlo secure plus
  • 1 Reply
  • 707 Views
jimslawson
i moved up to arlo secure plus hoping to move from 2k to 4k.
how do i do that?
Killhippie
Prodigy
Prodigy
@jimslawsonNo, its a 2K camera so you cannot upgrade to 4K and with a sensor so small you would not want to anyway. Basically its 2K or under, for example if you use the function to follow to zoom in to something in an image and follow it while recording, then it drops down to 1080P. Changing subscriptions does not change the hardware limitations.
  • 1 Reply
  • 708 Views
