Recently bought 4 Arlo Pro cameras on Amazon , only managed to install one the rest after successfully scanning the QR , the app isn’t able to find the cameras to complete the set up.
What could be the problem?
Mususa,
At what point during setup does the process fail? If you were able to set up the first, you should be able to set up the others using the same process.
You might try charging each camera using the included power cable before continuing with set up. Do you still experience the same behavior?
Arlo Pro 4
labels
Samsung SmartThings
