  • 1253 Views
jnsnAZ
Am  I forced to begin paying when I add a new Pro4 camera to my older Pro2 existing system?  I have not paid for 5 years and am happy with the limited services.
Your Pro 4 will need a subscription to get cloud storage.
jnsnAZ
my current setup (5 yrs) I get email alerts, and events are stored in Library for rolling 30 days.   Is that  called cloud storage??
30 days retention requires a paid subscription.  I suggest that you double-check that - I believe you will find that you only have 7 days retention.
Likely yes.
The only bases that support access to local recordings are the VMB4540 and VMB5000 - and you would certainly know that if you were using that feature, since there are several settings you'd need to make.  Even with those settings, you'd only see recordings in the app, and not in the library.
Other VMB4xxxx bases support local recordings, but the only way to see them is to eject the storage and connect it to a PC.
  • 1254 Views
