Where does one set up Activity Zones on Arlo Pro 4
  • 1 Reply
  • 513 Views
Jenelle
I do not see a way to set up activity zones in the MyArlo dashboard (on PC browser). Furthermore, how does one get AC power to the Pro 4?
If it is outdoors, then use one of these:
Although not shown in the pictures, this is not just a cable - the power charger is integrated.  The NAS bit is for the US, it would be a different suffix if you don't use US power.
Note that you don't need AC if you have a subscription (either paid or trial) for the cameras.  With AC, the activity zones are processed in the camera itself.  Without AC, the activity zones are processed in the Arlo Cloud.
If you see "Library" at the top of the screen, then select settings, "my devices" and then the camera. Activity zones are set up under "Video Settings".
If instead you see "Dashboard" and "Feed" on the left of the screen, then click on the camera, and then the settings wheel on the upper right of the camera image.  You'll also find Video Settings there.
  • 1 Reply
  • 514 Views
