Washington
I recently bought an extra battery for my Ultra Pro 4 camera and it was smaller than the original battery. Anybody know why ?
FWIW, there is no "Ultra Pro 4". There are Ultras, and various Pro models, including the Pro 4.
If the battery is a different size, then you purchased the wrong one.
- Do you recall if you purchased the XL version of your camera?
- Can you post part numbers of the two batteries? They should start with 308. The print is small, so you might want to take a picture with your phone and then zoom the picture.
Arlo Pro 4
labels
Samsung SmartThings
