VMA5400C solid amber all time
I just got a VMA5400A dual charging station and installed it per the instructions. When my good battery is installed, the LED light is a solid amber color. Arlo instructions say the amber light should be blinking during charging, then go green when fully charged. My battery is a Pro 4 XL and I believe it's almost fully charged. Arlo has no description of a solid amber LED. Does anyone know if this is working?
Do you have another battery you can test with?
If you put the battery back in the camera, what charge level are you seeing in the app?
My charger is the VMA5400C, not the A, but it has never flashed during charging. It has always been solid amber until the battery is charged at which point it turns solid green.
Hi, great to hear it! I'll try it and see if it goes green.
Were you able to get the battery to charge?
Hi, yes, everything is working fine. I appreciate all you info and help!
Arlo Pro 4
labels
Samsung SmartThings
