hello Team,
I've added two Arlo Pro 4 to my existing Pro 2 & WMB4000 installations.
The live videos and notifications work fine but no videos are stored on cloud and local usb
The videos are OK for the old Pro 2 devices , but nothing from the Pro 4.
Could you please assist ?
Thank you for you feedback
and about the local storage ? How can I check the recorded videos from the usb drives ?
regards
Do you have a subscription (either paid or trial) for the Pro 4s?
Were the Pro 4s added to your base, or did you connect them to your home wifi?
I don't have any subscription, but all my camera are linked to my Arlo base stations
The Pro 4s need a subscription to get any cloud storage. That policy started with the Ultra camera (launched back in 2018).
They should be recording to the USB storage in the base. But the only way to see recordings on the local storage with a VMB4000 is to eject the USB device from the base and connect it to a PC. The app and my.arlo.com only show cloud storage.
this is not very cool.... I would not buy new units if I was aware of the new limitations...
Any, how can I start a subscription trial ?
It should have opted you in automatically when you onboarded the new cameras. You can look in the subscription area of the app to see.
If that didn't happen, then there is no way to you to start it - you'd need to get a paid subscription. Not sure if Arlo support can do anything - I am tagging the two Arlo mods, in case they want to follow up: @JamesC and @ShayneS.
Note this is a holiday in the US, so any mod response will likely be delayed.
I've double checked : no way to find a trial plan nor paid subscription, online or from the mobile App.. I am stuck
Are you in a country where Arlo offers a subscription?
@Jimmy971 wrote:
I am in France
You should be able to get a subscription then. Perhaps try my.arlo.com
I dont have any other option
Jimmy971,
Subscriptions won't be available when using the iOS mobile app, you need to log in from a PC to get started.
Follow the instructions here: https://kb.arlo.com/000056588/How-do-I-subscribe-to-Arlo-Secure
I’ve checked already for pc browser and no success neither
I had to create a new account and rebuild everything from scratch, in order to access paid plans options etc
This is not really easy for endu-sers…
Arlo Pro 4
labels
Samsung SmartThings
