Tech support???
Are there any actual “Arlo people” that actually know about the product that are involved in support/help?
There is no phone number to contact (that I can find).
I started to try “chat” and it just asks questions like it’s trouble shooting.
No person.
Doesn’t chat imply you will be communicating with someone?
Are you supposed to ask about your problems here and hope someone can help you?
Trying to figure out the “subscription” thing is my issue at this time.
@Box22 wrote:I am aware of the paid options/services available but still can’t find exactly what the the cams & hub can do without paid services.
The details depend on what exactly you purchased (in particular, what hub model you have).
Here's a place to start;
Thanks for the response.
WITHOUT a service plan, your Arlo device WILL CONTINUE TO HAVE the following features:
- Live Streaming
- Push Notifications
- Two-way Audio
- Auto Zoom & Tracking*
- LOCAL STORAGE RECORDING*
To clarify the previous post a bit more the * denotes
Local Storage Recording are not available for all Arlo devices.“
Where do I find if it’s available?
@Box22 wrote:
Can the Pro4’s do local storage to VMB5000 without a paid subscription?
Yes. The local storage feature is in the base, so video from any camera connected to the base can be locally stored. In the case of the VMB5000, the storage is on a user-supplied microSD card.
There are limitations to the feature though, so IMO not a great experience:
- recordings are only available from the app (not the browser)
- recordings only available from the primary account (not shared accounts)
- no ability to make manual recordings or snapshots
- no thumbnails - videos need to be downloaded to the phone to view
- remote access requires router settings changes that some find difficult (and which don't work with some internet service providers)
Note: Accidentally clicked solved button. Not solved.
Yes. Thank you.
Finally decided to do complete reinstall. Reinstalled new app, factory reset base, synced with camera. (Only did one at this point).
When you first tapped "Solved" you could have gone back to "unsolve" it. I don't know if that works now - it likely is an option for only a short time.
The current apps support two different user interfaces (UI) - one that shows Library to view videos like you have as well as one that uses Feed (the new UI). You happened to select the FAQ for the new UI which is why you're having problems. These days, near the top of the various FAQs is a link that will point you to either the old UI's version of the FAQ or the new one. Here's the version you need:
So, click on Settings, My Devices, your hub. Select the local storage/storage settings selection (I'm on the new UI so can't see what the wording is but it should be obvious) and continue the setup.
Thank for the reply.
Got new email address. Set up new arlo account with new email. Reset hub.
Edit to above post.
Just saw in instructions push notifications are not sent if logged out.
Basically, what you're seeing is what you should get if you don't have a subscription. A sub allows cloud recordings but without one all you can do is use local recordings. Thus, when you go in the hub's settings for local storage, you see those videos but only with a blank thumbnail until you download them. That's correct and expected operation.
As for notifications, if you're logged out of the app, push notifications simply can't happen - you're logged out. You should just background the app and then push notifications will work properly.
Thanks that makes sense and everything appeared to be working like it should and then this morning I see the Pro4’s stopped recording.
Again everything is turned on and looks correct.
Adding to above. Email function also not working anymore.
Never had issue before.
Can you confirm that these cameras are in a subscription plan? It sounds like the trial subscription(s) expired.
They are not in a plan. That has been my whole issue.
I just want videos saved to hub so I can view them
with “feed”.
I know it can be done but things keep coming up.
As I said before, the local recordings DON'T show up in Feed. You must go to your hub's settings, Storage Settings to view any local recordings.
Sorry I screwed up when I wrote that. Recordings were showing in storage settings. They are grayed out you have to click to view.
Arlo Pro 4
labels
Samsung SmartThings
