SmartHub Device Ethernet connection to Cable Modem - Not an option
  • 2 Replies
  • 1757 Views
ydwivedi
I have Costco bundle of "Arlo Pro 4 XL Security Cameras and trying to Ethernet connect with Cable Modem (Spectrum) that does not have any extra. Its only Ethernet connection is fed into My personal WIFI - which has multiple Ethernet port outputs.
Can i use one of the WIFI port to connect SmartHub device?
Is that the best option?
Am I sacrificing some (or any) of the features?
Thank you in advance - Yogi
That will work, and you won't lose any features.
Some cable modems are actually gateways (combinations of a cable modem and a router).  Your setup sounds like you have two separate devices instead - the spectrum modem being just a cable modem and the my personal wifi box being the router.
ydwivedi
Thanks Guru (Mr. StephenB) for sharing your thoughts and details.
I am accepting the solution provided for optimum use of Arlo Security Cameras.
I hope that you and your families have a safe and wonderful holiday!
  • 2 Replies
  • 1758 Views
