Selling Arlo Pro
Selling my Arlo Pro. Just purchased Arlo Pro 4 with Smart Hub. Wondering if this is right? First I was going to delete my wife under granted access. Then remove all cameras from App, reset them to factory settings. Next remove my Hub then reset it also. Will it be easy to grant my wife access again to the new system?
Thank You
I think all you really need to do is
- on-board the smarthub and Pro 4 cameras
- share the new cameras with your wife
- remove the old equipment from the account
I guess you could reset the old base if you want, but removing it from the account should be enough.
Arlo Pro 4
labels
Samsung SmartThings
