Security Flaw
So my neighbor connects to the cameras with the arlo station being off and not connected to internet
He tethers internet off my phone and I even deleted the arlo app
You can hear the cameras triggering and only thing I can do is keep my phone off
The router shows intense GB usage Daily
This is a huge problem and security issue
Basically anyone can steal your internet or look at your data.
You said the system is closed and secure and that is a lie
Is there a White Hacker Reward?
Your system is far from secure
How do I get my money back or how do i stop the phone tethering?
Twitter here I come
Is this something the neighbor has told you or is this your analysis?
what model cameras and base/hub?
The base/hubs use a closed wifi connection that arlo equipment can only access.
some later camera models have the option to connect directly to your local wifi router modem and so bypass the base/hub completely.
regards the phone tethering issue, this would only work if you have a hotspot activated on the phone with guest permissions enabled to anyone.
So I would suggest a process of elimination to identify the path he maybe using to access your internet.
as you have already disconnected the arlo base station, remove batteries from cameras and observe your router internet usage as before.
If you’re still getting abnormal usage try removing any other devices you have like iPad, printers, Comcast tv, Google Home hubs etc. these can operate hotspots without you knowing.
Another thing to check is the other wifi bands like 5ghz that people tend to forget about if you have a dual band router.
I removed everything from router
My wifi has been off 2.4 and 5 and I do not broadcast the wifi name
still happens
@King_Wizard wrote:
He is recorded through out the week clicking stuff on his pc by his window near the sink.
How do you know he is actually accessing the cameras???
The icon normally changes color whenever recording or motion detection occurs - that doesn't mean he is making a recording.
All you are saying is that the cameras are recording him, you are not really providing any evidence that he is accessing the cameras.
@King_Wizard wrote:
the only thing i could think of is when you are setting up the cameras with your phone, somehow it saves the phone data to the hubso cameras somehow access my phone bc they arnt connected to router
No. The phone can access the cameras through the base, but cameras/base never access your phone. Notifications come through the Arlo Cloud.
The cameras of course will remain connected to the base even if the router is blocking the cloud connection (or if the ethernet is simply disconnected). Motion detection and local recording will continue even if the internet isn't working. But the cameras and base will be off-line in the app.
Have you tried disarming the cameras?
@King_Wizard wrote:
Camera clicks and my phone signal drops
Mobile or wifi? Do you mean totally drops, or slows down?
@King_Wizard wrote:
I even turned off all app access to arlo on router
What exactly did you do?
- Block access to the arlo domain?
- Disable all internet access for the base?
- Something else?
There is a camera directly on his windows, I mean like feet
I can see him, he just like stares at me all day lol
Arlo Balcony is the camera name if you wanna check it out
He is not a good person
He is always, always hovering when the internet is being weird
I was wrong about the icon thing, that is motion.
I found someone logged in on my device before and i logged them out.
I changed my password twice
I remove the physical wire from arlo base and power cord removed also
I did, that seems to work. Like if you disconnect them from the base and remove the wires
Mobile, slows down very significantly 3 bars to 1 or always 1
Blocked all app access to Arlo mean like anything with communications, entertainment, social media, and video communications.
Im only in wired mode currently with my pc
I disconnected all the devices 2 weeks ago bc someone was flicking my lights on or off
All smart bulbs have been removed and anything connected to wifi
wifi is off and has mac filters on to my pcs and tv only
So the only thing they can connect to and slow me down is the arlo system bc the wifi name broadcasts and can be seen
I don't see how the Arlo base could affect your mobile signal strength. It's a completely different radio (2.4 ghz wifi). He could possibly be using a jammer of some kind.
Though I would suggest that it would be best not to set up a camera that looks through his windows.
That doesn't mean he can connect to it. The network is closed so only the cameras can connect to it, and the password/authentication needed to connect to it isn't known.
Arlo Pro 4
labels
Samsung SmartThings
