Samsung note20 ultra
Maybe try adding web push, and see if you can see the notifications that way.
Do you need to use Samsung's email client? You could of course just use gmail or outlook apps on the phone.
Android mail features indenting and VIP inboxes that I use a lot. I would prefer Android outlook otherwise.
I am assuming this is not a user setting but the format of the image sent. Thank you again for your help.
Personally I use web push as the notification (not email), and use an iPhone. So I can't help much with the note20 email question. There are plenty of Android users here, hopefully they can help more.
Do you have animated preview enabled? https://kb.arlo.com/000062568/What-is-the-animated-preview-and-how-does-it-work
If you do, maybe try turning it off, and see if that resolves it.
@geer44 wrote:
The animated preview appears to be IOS.
No, it's both Android and iOS. But it might not be relevant to email notifications.
@geer44 wrote:
Thank you sir. I finally found the push notifications on PC-Arlo. It offers you to add email addresses for alerts.
There is a checkbox for web push ("Push Notification"). Is that checked?
You can enable both web push and email simultaneously. Personally I only use web push.
Do you have the same symptoms if you remove the email address from the rule, and only use web push?
Arlo Pro 4
labels
Samsung SmartThings
