Recordings on VMB500 with PRO4
Have Pro4’s and VMB500. I thought the Pro 4’s recorded video clips to the hub and stored under the “feed” WITHOUT the paid service?
I'll tag along on your post also because I have the exact same issue with Pro 4 and VMB4540. My post is a few below yours.
BTW, I think your model is VMB5000 (missing a zero)? So yours is newer than mine.
Yes VMB5000.
I bought the cams at different times and I know they came with limited time extra services and I did receive notices that the service was expiring.
With the trial Arlo Secure plan you would have received cloud storage. Once that trial expires, you will no longer see saved recordings within feed/library.
VMB5000 SmartHubs are capable of local storage but you would need to follow these instructions to set that up:
https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Thanks I have tried this and everything else I could find. Not much in the instructions are the same as what I see.
Mainly using an iPad but same issues with android phone.
To enable Direct Storage Access:
- Launch the Arlo Secure App.
- Tap Devices.
- Select your Arlo SmartHub.
- Tap
- Tap Storage Settings.
- Tap the Record Locally switch to the on position.
- Tap Local Storage Settings.
- Tap the View Recordings switch to the on position.
2. When tapped cams are in rectangles jiggling on the screen.
Arlo Pro 4
labels
Samsung SmartThings
