Problème d'installation
  • 1 Reply
  • 1079 Views
Placer105
Bonjour,  je viens de recevoir ma camera Arlo pro 4  après la sonnette du QR code il cherche la camera et ne la trouve jamais la camera.
En plus pour recommencer il faut remettre les codes wifi a chaque fois pfff
Merci pour votre aide
I suggest also trying with a PC (browsing to my.arlo.com).  Sometimes that will work when the app fails.
The network needs to be encrypted (wpa2).
Some folks have found that that using https://qifi.org/ to generate the QR code works when the QR code generated by the app fails.  So you could try that (maybe printing the QR code).
  • 1 Reply
  • 1080 Views
