Pro4 - cannot get notifications or recordings on library.
  • 5 Replies
  • 1855 Views
Stormymorn5577
Hi,
I have had this camera running for 6 months. Mostly works fine, but today seems strange. The 2 red lights show on unit if armed or not, is this correct? Also cannot get notifications or recordings on library. Any help would be good, contacted Arlo which didn’t help
5 REPLIES 5
Do you have a subscription?
In addition to the subscription issue, the 2 red LEDs are for night vision without the spotlight so, no, they should not be on all the time. They should only illuminate at night when motion is detected.
Stormymorn5577
Hi, thanks for reply. Arlo tech staff said I didn’t have subscription as it had lapsed, which seems strange as before usual monthly date. So I paid another month yesterday, but still shows no subscription, this camera is really annoying, got cut off several times on Arlo chat
Stormymorn5577
Hi, thanks for reply. Yes, I have night vision on, it seems 2 dot lights appear when I have alarm armed, once I change to disarm they turn off, is this correct?
This camera was working ok for last 6 months, only yesterday I have had issues. Not the iPhones, and I have deleted & reinstalled app. I can view camera on app, wifi is fine. Issue is that when it is armed, seems not picking up any motion so no alerts or recordings in library. Any help would be great, also camera is fully charged as I have set up high with solar panel. Happy New Year to you all👍
Again, the IR LEDs should only turn on when motion is detected at night. If they're on all the time the battery can run down prematurely. I think there's an issue with the camera so pursue your subscription issue and get in touch with support.
  • 5 Replies
  • 1856 Views
