Pro4 camera on solar panel constantly going offline
I have three Pro4 cameras, one on a solar panel that went offline almost daily. It's in a great spot for solar and for capturing a large part of the property but it is pretty high - hence the desire for solar. I even moved the router and smart hub to a spot in the house where this camera consistently gets a strong signal. I had to drag out the ladder daily because the camera was offline. Finally, because the only unique thing about this camera was the solar panel, three days ago I disconnected the panel - and have had no problems since. Any ideas what may have been going on? It's an Arlo solar panel...and packed up ready to be returned unless someone here can help solve this problem! Thanks for any guidance or help you can offer!
IFM,
Have you tried reconnecting the solar panel to see if you continue experiencing the same behavior? If you can successfully replicate the offline behavior after reattaching the solar panel, this could give more insight on the cause of the issue.
A replacement panel would likely solve the problem. In general, solar panels don't cause problems b ut a single faulty one can.
Yes, thanks. That was my conclusion. I returned that panel and plan to try another when the weather is better.
Arlo Pro 4
labels
Samsung SmartThings
