Pro4 cam - What is the latest available Firmware #
You can always check here:
https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Firmware-Release-Table/m-p/1920885#M791
Thanks...but I've seen some indications / comments that the list is not kept up current...was hoping some members might be able to tell from their personal experience.
For Example:
Firmware on my Pro4 cams is: # 1.080.22.3_56_e704b23
The Firmware list shows # 1.080.22.2_49_0c674b2
So the questions are:
Which # is more current?
Is there a more current version than either of these?
I agree that updating the list may have a lag. I see the same firmware as yours on my Pro 4. That would seem to be the latest available for production units.
I DID NOT accept this as a solution.
I don't see any solution as being accepted.
Apparently a moderator established it as being accepted...I responded to that to clarify...the acceptance was removed.
Pro 4 firmware is 1.080.22.3_56_e704b23
FWIW, I just got Firmware updates on my Pro4 Cams:
Firmware # 1.080.23.0_14_00cfb6d
Dated 03.20.25
Arlo Pro 4
labels
Samsung SmartThings
