Pro4 Firmware # 1.080.23.0_14_00cfb6d Upgrade
03/22/2025
Just moved 3 Pro4 Cams off WIFI to a Base Station and was notified that a 03/20/2025 Firmware Upgrade was available.
I upgraded all of them to Pro4 Firmware # 1.080.23.0_14_00cfb6d.
Was curious about what changes / improvements the 03/20/2025 Firmware upgrade was supposed to make on the Pro4 Cams ?
Any clarification would be appreciated, thanks.
You can check https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Firmware-Release-Table/m-p/1920885#M791 but there is no more info there than there is for the app in the relavant app store.
Agree...never been impressed with those listings...that's why I posted a note here in hopes someone might actually know.
For the Record...I did NOT accept any posting as a solution.
My question has not been answered.
You should be able to click on the three dots above the "solution" and select "not the solution".
I did that for you.
Didn’t know that, thanks.
Arlo Pro 4
labels
Samsung SmartThings
