Just got a 4 camera Pro4 set. Have an existing 4 camera Pro set with Hub. Can I combine these.? ... I read only 5 cameras on the hub, I started installing and on 3rd Pro 4 all cameras went offline.....Removed the 4 Pros and reset the hub the Pro4s are back..... Can I install the Pro 4s without the hub
Yes, they can be directly connected to your home wifi.
So my thought is connect my pro4s wifi and the pros obviously to the hub. Will that work?
Yes.
You will need a subscription for the Pro 4s to get recordings. But wait for the trial to end before getting that.
Arlo Pro 4
labels
Samsung SmartThings
