Camera is brand new out of the box and wont connect to WIFI. It does show up as discoverable devices though.
I have reset the Netgear7550 router and made sure to change the ssid and password to only use letters and numbers.
It goes through the setup sequence with no problem and I get a chime once I scan the QR code.
After the chime the blue light flashes 10 times then I get a quick amber flash and then no more lights from the camera.
I have tried the desktop and mobile apps to no avail with the same failure point.
I have a 3 camera arlo system on a different wifi network and they work great.
Thank you ahead of time for any help!
Do you have a VPN running on your phone or computer? If so, try turning VPN off, do a hard reset on the camera, and then attempt to connect. VPN was the issue with my iPhone the first time I tried to connect a Pro 4.
I have the VPN disabled and have hard reset everything... even the router back to factor specs just to be sure any changes I made in the past were not the issue.
Arlo Pro 4
labels
Samsung SmartThings
