Pro 4 will not record on motion
Pro 4 is providing a video stream but will not record on motion. I have other Pro 4s in other locations with the same settings and they all record without issue. I'm using the Advance Subscription. Also trying to find out if I upgrade to the enterprise subscription provides phone assistance.
- Double check that the camera that isn't recording is still in the subscription plan.
- See if you can make a manual recording when livestreaming the camera.
- Make sure the camera is armed in whatever mode you are using: https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
- Run the motion detection test: https://www.arlo.com/en_dk/support/faq/1114344/How-do-I-use-the-motion-detection-test-for-my-Arlo-de...
Arlo Pro 4
labels
Samsung SmartThings
