Email notifications would happen without intervention of the app. Push notifications are a function of being logged into the app.
I can't say for sure that you can remove her cameras - she may need to remove your access from her account. However it works, it won't have any effect on her app/account at all.
Yes, all cameras will show in your account. However, you can't disable push notifications from her cameras - she would have to do that which would also disable hers - push notification settings are global. If she changed to email notifications, she could exclude you but the notifications would come after the video is uploaded rather than immediately.
Also, if I decided to remove her cameras (since it'll be too much activity for my sanity) and only keep mine on my email, would that affect her app as well? Or is it different on her email because she's the administrator?
Arlo Pro 4
labels
Samsung SmartThings
