Pro 4 only charges to 4%
Have had issues with it charging.
Checked and cleaned the connections
Using the Arlo power plug.
Took out the battery and checked it.
Charges only til 4%. That is it.
While it could be faulty hardware (camera, battery or charger), try this FAQ that may help. It's for older cameras but may prove useful:
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
The key is to attempt charging multiple times to allow sufficient charge in the battery to let it then charge fully. It's a better practice to charge proactively rather than letting the battery die.
Arlo Pro 4
labels
Samsung SmartThings
