Pro 4 not recording events. It was working 3 or 4 weeks ago now it just shows notification.
It notifies but doesn't show the event anymore. I do have a subscription and checked to make sure it was
still paided up.
Which UI are you using - the old one that shows Library to view videos or the new one that shows Feed? What subscription do you have, an older/legacy one or one of the new ones (Secure or Secure Plus)? If using a legacy sub, verify the camera is included as enabled in the sub.
Nothing seems to work. Suggested to take system completely down and start over. Whatever is causing the problem may show up.
Arlo Pro4
Software: ver 4.3 (5832), Released mar 21 2023
Subscription Arlo Smart
Connected to Solar (its own)
mtncouger,
Within your Arlo Secure app, check the active mode within Routines. Is the camera armed and are there rules within the active mode telling it to record on motion?
Under rules(Arm Home settings), it does not have a recording option. Just notify on motion and audio. I even deleted
the rule and re-added but still just notify.
If you have a subscription for the camera, then you should have an option to record.
Arlo Pro 4
labels
Samsung SmartThings
