Pro 4 cameras
  • 7 Replies
  • 2154 Views
2Bucks
With my older Arlo Pro and before I did the system upgrade on the interface of things on my phone etc.  I use to be able to select the order of my devices by just dragging the device in the order where I want it to appear on my phone etc.   I had to delete and add back one of my devices to fix an unrelated problem and it put that device at the end of the order of appearance, where I would like it back to where it was.  How do I do that with the new interface?
7 REPLIES 7
DannyBearAgain
The camera re-ordering feature is still working using the older UI.
Will re-ordering Cameras work at all  using with the new website UI?
2Bucks
Can you walk me through it?  I've been trying to do it but i can't seem to get to the screen I use to do it or anywhere else that works.
2Bucks
I have the new UI.  Are you telling me i can still use the old UI somehow?
No, you can't go back.  @DannyBearAgain is still on the old UI, and is just telling you that it still works with that experience.
2Bucks
Ok let me try again.  I have the new UI.  Can I re-order my devices there?  If it is possible can someone walk me through it?  I've tried everything I can think of to do it.
Yes. In the Devices display, click on the 3 dot menu top right and reorder. Click Done when finished.
2Bucks
Got it thanks!   I had gone there before and seen them wiggle and tried to move but didn't hold it down on it long enough.  Thought it was going to be like wiggling apps on my iPhone and would delete it. LOL
  • 7 Replies
  • 2155 Views
