For those that purchased this from Costco, where do you get a spare battery and charger?
I only see the Pro 4 battery / charger online but not the battery / charger for the XL model.
Igbalfa,
Yes. You can find the extended Arlo Pro 4 battery here: https://www.arlo.com/en-us/accessories/VMA5410-10000S.html
As mentioned above, the charging solutions are the same for standard and extended batteries.
The XL batteries are charged in the same charger.
I am assuming the Pro 4 XL batteries are different than the Pro 4 batteries right?
Igbalfa,
Arlo Pro 4
labels
Samsung SmartThings
