Pro 4/5 magnetic mount compatibilty?
  • 2 Replies
  • 3533 Views
  • 2 Likes
HMishkoff
Will the magnetic mounts from my ancient original Arlo cameras (VMC3030) work with an Arlo 4 (or an Arlo 5)? Or will I need to buy new magnetic mounts when I upgrade to my new cameras?
(I think I've read that my adjustable screw-in wall mounts from my old cameras will work with the new ones. Is that true?)
No. The new cameras come with the new mounts so nothing needs to be purchased. Screw-in mounts for all the cameras are the standard 1/4"-20 thread so old mounts will work with the new cameras.
ShayneS
Hey @HMishkoff
The Pro 5s comes with the standard screw mount and the Pro 4 came with the magnetic wall mounts. This may be dependent on kits as well. Hope that helps a little.
  • 2 Replies
  • 3534 Views
  • 2 Likes
