Seeking recommendations for best mount to attach the Pro 4 XL. I have the Pro 4 and have ordered the XL housing and larger battery. I understand that the magnetic mount is not advisable and would probably prefer a screw-in type anyway. So I suppose my options are: (a) screw-in mount that came with the base Pro 4, (b) Arlo certified indoor/outdoor VMA1000, but I'm not positive that it works with the XL; (c) Third-party item - Wasserstein or similar. I'm just looking for a good, strong mount that will securely hold the larger and heavier XL. Comments and recommendations please. Thanks!
Thank you for your reply!
Actually it won't work at all. There is no metal in the back of the XL housing, so it won't stick to the magnetic mount.
I've used this option with an upgraded Ultra and have had no issues. Though some have found that the camera tends to droop.
Arlo Pro 4
labels
Samsung SmartThings
