Notifications on each camera
Running iOS. Not getting the notification dot on the app icon on the Home Screen (notifications are on on settings). Library will show new recordings but each camera does not show the number. This seems to have started after the last update.
almostsane1,
Try uninstalling the mobile app, rebooting your mobile device, reinstall the mobile app and test again. Do you still experience the same behavior?
Arlo Pro 4
labels
Samsung SmartThings
