New Arlo Pro 4 will not charge; battery shows low even after charging
Just purchased Arlo Pro 4 and found the battery low even after hours of charging. I can verify the LED comes on when charging and the camera is fully inserted into it's shell.
The camera does not require a hub/base station. It is connected to my 2.4Hz Wifi directly.
Also the app does not show a percentage on the camera of how exactly low it is.
Any suggestions?
The LED should only come on when power is connected and shouldn't remain on. Depending on the LED setting in the camera settings, a full charge would then illuminate the blue LED.
If the battery is fully discharged for any reason, read the FAQ in the support section that details how to get a full charge. Basically, it has to be plugged in multiple times to get sufficient charge in the battery to allow a proper charge.
You should get an email to notify <15% battery level (of course, if it's dropping rapidly that could be after the battery is dead). A good strategy is to occasionally check the level yourself - when the icon turn red it's below 25%. Recharge proactively - don't wait until it's a problem.
It appears then that I have received a defective camera or battery and will need to return this device.
Thank you for your help w/this issue.
I guess I will be keeping this camera now. 🙂
Hi JRock17, I would try the install and reinstall. Maybe even space it out a day in between installs (just something that worked for me). In addition, if it still doesn't show a percentage, try using the camera for awhile. If it truly isn't charged, it won't last long with usage. You can also take a fully charged battery from your other camera and insert it into the problematic camera (just to be sure you truly have a fully charged battery).
However, the bigger issue is needing to get that percentage icon to show up and work. Otherwise, I don't think the app can acknowledge when the camera will truly have low power. Good luck!
Arlo Pro 4
labels
Samsung SmartThings
