Need help deciding
  • 1 Reply
  • 1089 Views
RedJeep22
I'm considering purchasing two Arlo Pro 4 cameras. Do I need to subscribe to any program? Do I need a home base? TIA
The cameras can connect either to your home wifi or to a base/smarthub (VMB4540 suggested here).
You will need a subscription to get cloud storage and activity zones.  With the smarthub, you could use direct access to local storage as a substitute for cloud storage, though that does have a number of drawbacks.  The only way to get activity zones w/o a subscription is to connect the cameras to AC power.
  • 1 Reply
  • 1089 Views
