Mount near flood light
  • 1 Reply
  • 537 Views
lc53
I have a motion activated LED flood light over my garage door..Arlo doesn’t offer a flood light camera which can get power with a direct connection.
Does anyone know if my existing floodlight is likely to interfere with an Arlo 4 camera. What is likely to work better? Mounting above or below existing floodlight.
Thanks. I know I can try different locations but I'd like to minimize extra holes
The Pro 3 floodlight can use both battery and AC power so could be useful. However, with an existing floodlight, that should work fine. You may need to test motion sensitivity to align with the lights' sensitivity.
  • 1 Reply
  • 538 Views
