Motion detection stops working
  • 1 Reply
  • 949 Views
IBBoard
I've got an Arlo Pro 4 connected to a VMB5000. There's an SD card in the hub and the Pro 4 is recording to it. We've noticed a few times that the camera stops recording and seems not to trigger on motion, but a few "remove, reset, sync" cycles normally fixes it.
Now, however, it's just absolutely refusing to do motion detection, even in the test mode. There's no orange light and no recording.
I've tried:
I'm not using activity zones. I'm not using automation. The camera and the hub are on the latest firmware. The camera has decent signal and is within ten feet of the hub through thin, modern-build house walls. All of this worked before, I'm just trying to get a motion detecting camera to detect motion again!
(I've just enabled "Audio detection" and that seems to be working... but not motion detection)
My older camera still works fine. But it worries me that some of these "why has my camera stopped doing motion detection" threads go all the way back to 2022 😐
Did you try a hardware reset of the camera?
  1. remove it from the account
  2. open the housing and press the button inside until the camera LED flashes orange (~15 seconds)
  3. add the camera back to the account
  • 1 Reply
  • 949 Views
